Fuel pump question
Pastell02
I have a 75 with a 32/36 carb and I recently pulled the fuel tank had it cleaned and painted. While it was out I also replaced the fuel lines from the fire wall to the carb. My question is how long should the engine crank before getting fuel to the carb? I've double checked the fuel line from the tank forward and it's clear.
Thanks,
Try pouring a little fuel down the carb throat and crank to get it to fire.
Caution - too much and it can backfire and big flames.
Most starters spin a bit slow for the pump to really have enough oomph to start sucking fuel through. The high revs of a running motor do the trick.
HTH Beaner7102
if this car SAT for years - the pump diaphram is toast - replace the pump and yer good for another 25 years
ACHTUNG! - DO NOT INSTALL A ELECTRIC PUMP! -
replace every rubber fuel hose - you don't need to see gas
leaking for a hose to be bad - it's old and sucking air through its
rotten rubber contributing to your long cranking times
'64 R27 250cc #383851 18,000m
Check the connection at the hard plastic line. It doesn't have a bulge or barbs to help grip the hose so you need to get it right otherwise it will suck in air at that point.
rtheriaque wrote:
well then -
that can/could be.....
low - or uneven compression
valve adjustment
ignition timing
worn spark plugs
STALE GAS
choke adjustment
huge intake vacuum leak
brake booster hose off someplace ?
I've doulble checked the lines there are no leaks and the clamps are tightened.
CD, everything on the list below is set/adjusted to spec compression was good even across all cylinders (timing is just static as I havent been able to get it running long enough to get a timing light on it). Choke setting hasn't changed from when it was running fine, gas/spark plugs are fresh. The line from the booster appears to be fine the fitting at the booster wiggles a bit could that be an issue? I haven't looked at the fuel pump yet that will be tonight.
well then -
valve adjustment
ignition timing
worn spark plugs
STALE GAS
choke adjustment
Have you tried disconnecting the fuel line at the carb, directing it into a container and cranking?
Pull the top cover and see if there is fuel in the float chamber or if the entry to the jets are glued up. Might be worth pulling the jets one by one and squirting carb cleaner through the jets and through the mounting holes on the carb body.
If it fires from unmetered fuel you need to work backwards through the metered fuel path.
Simeon, I'm not getting fuel to the fuel filter at this point.
order a NEW machanical pump from BLUNT today
but before you do
disconnect the hose from the carb- place end in bottle and crank for 30 sec.
always a possibility you have a major blockage from the tank
pickup strainer, a crushed hose/pipe between the tank and pump
LOOK!
Yeah, I'm with CD on this one-
put vacuum on the fuel line and see if you can get fuel from the tank.
MityVac is good for this sort of thing.
The land cruiser sat for 10 years, and there was half an inch of goo
in the bottom of the tank that effectively plugged the pickup solid.
The 122 had junk in the tank that kept jamming the pump valves open,
making the pump appear dead- but a good cleaning fixed everything-
for a while.
If you can get fuel from the tank, then suspect the pump.
hth
  • 2 months later...
Just a follow up on my fuel pump issue. It did turn out to be a bad pump I installed my new pump(Thanks Blunt Tech!) today and fired up after just a bit of cranking.
Oh nice .. Now go drive it
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
