Problem diagnosis please!
bzuva
my guess: you're not charging. Everything works just fine until the battery drains down.
14 years ago I was at Lake Isabella and in the morning the light flickered ever so slightly. I immediately headed for home .... 177 miles later (9 miles from home) the battery finally gave out on I-5 in Downey.
A new Bosch alternator took care of it .... still running just fine.
Carl
out, it's probably missing the wire bail that's supposed to hold it in place. Note that there are 2 screws in the alt. body, each with a little clip under it; That's what holds the bail in place. They're spring steel, and will break and fall off without your noticing. With the wire bail, the plug won't fall out from vibration.
