No Heat in Car
You are 1/3 the way into pulling the heater box. I highly recommend doing it now that you have the heater hose and valve out.
You can fabricate a simple angle-shaped piece of aluminum that bolts or rivets to the plastic fan cover (totally eliminating the stock mounting tab).
Installing new heater hoses (especially the short one) will help secure the valve in place. The large grommit in the bulkhead will also help. Old stuff will most likely flop around.
It really isn't that hard to pull the box from your car (no A/C helps!). I just did this yesterday to a 74. ALL of the control cables and wires do NOT have to be removed from the levers. Only (1) wiring connection at the front of the heater box has to be disconnected.
  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Mike wrote, "...Below that you won't get the typical sock-melting heat that you should from a 2002... "
Also something others have not mentioned. if the heater core is full of crud you will get no heat, even with a new valve - no water flow = no heat.
I replaced a valve a while back and it made no difference. I finally pulled the box, had a Rad shop cleanout the core and now I get melting socks like Mike. Just thought I'd mention it. Beaner7102
I've already put everything back now. The lever works perfectly and I will test the heat tomorrow. I think i'll pull the box out when i change the blower fan at a later date. Interesting thing is that when i switch the fan on i hear a click and i see my volts go down as if it's working. Does that make sense? The fan just doesn't move.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2000 Porsche Boxster
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
One of the (2) wires at the fan motor may have come loose - or the motor may be kaput. My fan motor was brand new about 10 years ago, but was hardly used. I had to replace it again along with the motor cover and fixing some old re-appearing cracks in the housing with JB Weld.
I don't need to turn the fan on in my car with the heat lever about 1/2 way "on". The outside air makes the fan turn and blow air thru the box. Shoe-melting heat in my car. I have to open the vent window.
hmmm, i'm in los angeles so don't really need heat that often or that intensely. i just like to have everything working on my cars. so i guess i'll tackle the fan eventually.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
try spraying the fan with some lube and reach in there with something like a long screwdriver to try and spin it...it might just be stuck...mine's been like that a couple of times because it seldom gets used...a bit of pb blaster & a nudge always gets it spinning
if the motor is bad would the volt meter still react as if another device was switched on?
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
