The Heist.
heist
Send me the dimensions of the plates for the rear upper shock mounts and I'll draw something up for you. I need to know maximum OD of the plate and what size the hole in the middle needs to be for the upper shock bushing. If I can ever find that pic of the rear strut brace that Brent made I'll post it.
Plugged the 2 lines that go to vent and put my hotspark pointless ignition in. Just need to do the timing tomorrow. Picked up some R40 lugs too :)
I figured if I was going to be doing all this bodywork I might as well take the orange sidemarkers off. They are just too big and obnoxious. Also yeah the welder should have been turned up for the newer welds I just was in a hurry. It was a previous setting from when I had to deal with the paper thin fenders. Also I will get the dimensions soon thanks!
Why are you glassing over the flares? They look pretty straight as they are... why not just throw on a bit of filler and paint over that? Looks great so far, keep the updates coming!
Amazing... just by the look of it, I am already tired...anyhow good work. One thing you might want to do while you are at it is to throw out that old fan, and put in an electrical push/pull from the back of the radiator. I am sure most will agree, it will save you a lot of grief and space.
Good Luck...cheering for you...
THOU SHALT DRIVE AN 02
