Am i not driving my car enough?
asifallasleep
Having issues with my car starting. My mechanic tells me i need to drive the car at least 1 hour a day to keep the battery charged. Always a hard start. Somehow I feel the issue is fuel delivery related.
I drive the car 3 times a week approximately for 15-20 minutes. Should I buy a charger for the battery? Seems like a pain. I've had newer cars that could sit for a week and crank right up.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2000 Porsche Boxster
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
Mine starts fine after 1-2 weeks of sitting, 2-3 weeks & it's slower. I think cold weather can affect that too. Some people have mounted the trickle charger in the engine bay, so it makes it easy to connect/disconnect the power cord. They come w/ a mounting bracket.
you offer no facts on your "hard starting" ?
what's been done?
define "hard starting"?
your method of starting the car?
the history(long) of the car
fuel system, ignition, settings, timing, jetting,
compression conditions?????????
this can be caused by 101 things
and.... "I drive the car 3 times a week approximately for 15-20 minutes"?
causes more harm than good
you never completely evaporate or burn off internal condensation
this car needs runs of 30 - 60 minutes, under load, frequent fresh gasoline
added, frequent oil changes to maintain it in top condition
What the others say +1.
With cars, every time they are started they should run for enough time to completely heat the engine and oil. Starting an older car and driving it for a mile or two and turning off can fracture gaskets and foul plugs.
All my cars start right up, although the KisselKar & Packard take a little longer to wake up after hibernating for 6 months.
Andrew Wilson
Do you ever drive behind someone that has water trickling out the exhaust pipes? Not just a little bit, but a stream? Lots of condensation inside the exhaust system from not driving long enough to evaporate the water. Thank goodness most newer cars have a stainless steel exhaust system.
In my opinion, you should allow at least 1 hour of driving time with some good highway time to get the operating temp of engine, tranny and rear diff. up. Idling in the driveway won't cut it.
Battery Tender A+
well just as i thought, i changed the fuel filter and now car starts fine.
not sure how to handle the short trips. most drives are to the tennis courts and back or even to the grocery store. i work from home and most times it's short trips around LA. i'm central to everything.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
Is your mechanic a meth dealer on the side... WTF is up with the wifes tales these guys come up with... How old is your bat?? if the starter wont turn then get a new batery/// If it cranks at a good rate and it dosent start, could be fuel could be ignition... BUT no mater what find a new
MEC NIC!!!
Scott B.
1969 2002, 1972 2002, 1967 1600, 2001 540It
