big problem today
mikea
while driving up a long grade
for the first time ever i noticed my temp gage rising
and my speed slowing.
I turned on the heat in the car, but still no relief
I could not really pull over and was headed in the caldecott tunnel
when I declutched I heard a loud noise
when I could finally pull over I saw that the fan blade had
cut into the radiator- shredded it
I had the car towed home
later when it cooled i could easily start it ( very briefly )
to drive up into my garage
so i need at minimum:
new radiator
new fan.
but I notice that the engine seems very loose on its mounts
I can move it back and forth easily
so we get to my question:
is it the motor & transmission mounts that keep the engine fixed?
somehow the whole engine must have moved forward
to allow the fan blade to shred the radiator.
what about the urethane engine & trans. mount from Ireland?
will this solve it?
also: I never had a fan shroud- is this standard on 2002?
I am going to put it all together and see if there was any real engine damage
from over heating.
so:
1. does anyone recommend the urethane mounts from IE or elsewhere?
2. do I need a fan shroud? dealer item?
3. any options on the red fan? the blades seem quite flexible!
4. should I change the water pump while I am in there?
your to do shoping list of parts:
radiator
red "tropic" fan blade
water pump
all the front coolent hoses
v-belt
alternator bushings (urethane)
motor mounts (rubber)
right motor mount limit stop bracket if missing
trans mount (rubber)
weld and reinforce broken steering/motor mount arm on subframe
1-gal. BMW Antifreeze
'64 R27 250cc #383851 18,000m
heres some numbers that you need
radiator
red "tropic" fan blade 11520786120
water pump 11519056401
all the front coolent hoses I can send a list
v-belt 12311268675
motor mounts (rubber) 11811109352 and 11811104588
right motor mount limit stop bracket if missing 11811101273
trans mount (rubber) 23711245515
1-gal. BMW Antifreeze 82 14 1 467 704
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
Early cars have a completely different right side mount bracket--it's a bent over piece of heavy steel plate--that will fracture over time and allow the engine to shift. Later ones are welded up steel with the llimiting bracket as shown in CD's post. Use the later style if you have an early one.
Also, the plastic fans will fail with age--my 73's gradually started shrinking as pieces broke off the blade tips until it was easily 3" smaller in diameter than originally. Still worked OK, though, and didn't damage the radiator as the pieces came off.
You may be able to have your original radiator recored with a 3 row core radiator (like what the late, great Curt Ingraham used to offer). Check your local radiator shop; the part number used to be a RADAC 25 or 26.
Glad you didn't lunch your engine.
cheers
