How to reconnect heater control cable
BMW0299
My heat/cold control cable is loose, apparently disconnected from the heater valve in the firewall. I can feel the end of it. Is there an easy way to reconnect it? I hope. I couldn't find anything doing a search.
the end of the cable goes thru a small hole in a bolt that is secured with a nut and lock washer.
i going to say it would be blind luck to get the cable end back thru the hole
the only other way is to remove your center console and drop the heater box.
and that means you might as well refurbish the heater box while its out
and that means you might as well.........................
72 2002tii
1988 535is  “Maeve”
it is possible to do without taking everything apart. i did it last month. had wife on drivers side of car with flashlight looking through grill guiding me as i blindly moved the cable with the one hand i could jam in there. wasn't fun, but only took about 15min.
It must be connected correctly or the valve won't open and close properly.
The open/closed positions of the valve control lever -
Another view of the valve -
You do have tiny hands and nimble fingers, right?
good hands
cordination
patience
good light
tiny tools 1/4 drive socket or stubby wrench set
AND # 1 PRECAUTION ! DO NOT EXERT MUCH FORCE
AGAINST THE WATER VALVE BECAUSE YOU WILL BREAK
THE BRITTLE PLASTIC MOUNTING EAR THAT HOLDS THE VALVE
IN PLACE. THE WATER HOSES CAN STILL HOLD THE VALVE
INPLACE - BUT IT'S A WARNING
from the control arm on the valve and the cable end didn't snap off...
1. Carefully note the arm's positon in relation to the valve and the setting on the dash control. It's possible to install wrong 3 ways, and correctly only one.
2. Unbolt the control arm from the valve (don't forget to note the arm's position and the control lever's position)
3. loosen the pinch bolt and reinsert the cable thru the hole in the bolt; tighten.
4. Reinstall the arm back on the valve the same way you removed it--be sure you didn't inadvertently move the lever whilst wresting with the cable .
Good luck.
  • 1 year later...
please do this again and have this recorded on video. i am willing to do a pg version to edit out all the "bleeps". nevermind...ill just kill the sound all together.
