Help with the next mod
Hi,
Few things done to my car but i do sense needs more.
Daily driver with ocassional (2-3 times a year) track time.
Things done so far:
15" Konig wheels new 195 rubber
new brakes ft and rear
engine is from a 2 liter from a 320i, e-12 head
webber 38/38
tii exaust manifold, ansa exaust system
petronix electronic ignition
electric fuel pump
320 rad
battery in trunk
ft and r strut bars
euro turn signals, hela fog lights
H&R sport springs
Bilstein HD shocks
New strut mounts
all bushings and subframe
Led lights
Rear spoiler
Interior:
sound deadening
recaro front seats
6 series rear seat (buckets)
new headliner
signed nardi steering wheel
new one piece dash
custom consol
alpine audio system
new salt and pepper carpet
new seatbelts
new plywood door panels
What else, next can be done on this car?
What mod makes sense, ireland engineering sway bars for example?
I appreciate your input.
post-48330-0-86997500-1435952627_thumb.j
With all the suspension mods you mention, I'm puzzled why the front and rear sway bars are still (apparently) stock.  Larger bars (22mm front, 19mm rear) with urethane bushings would definitely help your cornering by keeping the car flatter.  And larger bars won't affect the car's ride either.
And if you're planning long trips or lots of freeway driving, consider a 5 speed conversion with the stock 3.64 diff.  The overdrive 5th speed will drop your rpms approx. 800 at a given speed; that's a significant difference in noise level at freeway speeds.  But if it's mostly around town use, it probably isn't worth the effort.
cheers
Thank you everyone.
I don't drive hwy at all, I do like 5 speed but 4 will do for now. I've driven short distance on hwy and the engine rpms are way to high for a long ride for sure.
Driver mod is on my to do list, i have few advanced driving classes booked, thank you.
Sway bars seems the next logical mode, i do see them availabale from ireland engineering. Are there any other options except Ireland Engineering?
For your type of driving just stick w/the 4 speed.
Others are 100% right. Sways are next on your list. ST's bars are pretty well used as well and from what I've heard install more like stock that IE's.
Pittsburgh, PA
67.5 Datsun Roadster
72 2002 Colorado
89 325ix
99 318ti
04 x5 3.0
