2002 Parts Galore
I am clearing out the shop and have a ton of parts to sell. I have used: light tan and a navy blue interiors, a tobacco back seat, doors, glass, differentials, transmissions, grilles, interior handles (door, grab, and window), wheels, hub caps and rings, seat belts, headlights and tail lights (square and round), good original wood shift knob, shift boots, wood gauge cluster (tach and clock versions), wood trunk floor, Weber 32/36 with modified BMW air cleaner, exhaust manifold aluminum shield, a pair of 1972 bumpers with guards, pedal box with a small hole, driver fender, wiper lever, trunk vent ducts, 1600 and 2002 engine fans, driver door mirror, spacers for the vented rotor conversion, inner drum brake parts, exterior driver door handles, black driver's seat, black door arm rests, e-brake boot, shifter, hubs, rotors, clutch discs, flywheels, steering column, 4 spoke steering wheel with pad, exterior belt line trim, pistons, oil pump
New Old Stock in the box parts that I have: tii air filters, tii caliper rebuild kit, M10 engine bearings, clutch release bearing, distributor cap, rotor, rear wheel bearing, thermostat, stop light switch, pull type wiper switch, ignition coil, steering idler arm bushing, slave cylinder, brake pads, under hood insulation(still has peel away sticky backing), turn signal seals, sunroof seal, '72 points(BMW package), condensors, piston rings, wiper relay, door brake, water pump, flex disc (guibo)
I'll be happy to take pictures of parts. There are many other parts available, just ask! I will ship anything anywhere as long as you pay for it.
Please call John McHenry at 366 782-7133 or Motorsport Connections at 336 659-8988
I'm interested in the underhood pads. Shipping to 21208. I have a verified PayPal account. Thanks. im02crazy AT yahoo DOT com
1969 2002 Sahara  Manila  :)
Thanks John, I will wait for your photos of the front seat belts in the next day or so and the water divider if you can find one.
HBChris
John,
I would like to know if you might have a spare tire wheel well some where in the pile of parts you have for sale looking for one for a 1967, 1600.
Thanks, Jose
Jose3523@juno.com
I could use 2 idler arm bushings. shipping to 92646. Also a automatic shift plate indicator for a 74 and a center grill for a 74 lastly a belt line trim piece that goes behind the drivers door to the trunk lid. Pics would be great. Thanks Thomas Kowalke
I am quite interested in that Tobacco rear seat... exactly what I need! I'll give you a ring in the AM (don't want to bug you as it's approaching 9 your time).
or email me using the contact form above or red 86 alfa @ gmail DOT com. Thanks!!
1973 BMW 2002 Sahara
Hi John -
I'm interested in a 245 Getrag 5-speed from an '81 or '82 320i if you have a good one.
Also looking for a 3.64:1 LSD if available.
I could possibly pick up since I'm in Northern VA with vacation coming up.
