icustum m20/2002
robdaehn3
Here's my 2002, she isn't complete, she needs finish body work and paint (Our beautiful baby girl arrived and paint will have to wait). my 2002 contains:
ENGINE- fully built port/ polished m20 w/transmission(custom trans tunnel/ support)
followed w/e30 drive line and LSD,custom 2 to 1 to 2 mandrel bent 3 inch exhaust piping, all UUC billet short shift components, powder coated valve cover/intake, E36 318is radiator,stanless fuel/return lines, E30 318 fuel pump, complete custom wiring: VW Jetta fuse box, No wires visible in the engine bay, all wires+coil+battery connect neatly put away underneath the dash .
STEERING-320i rack 'n pinion, E30 steering colum and steering nuckles.
BRAKES-Wilwood calipers/rotors/ proportioning valve, Lee's hats/brackets/lines, Compbrakes hydraulic handbrake,Complete E30 brake/Gas pedel assembly + throttle cable,TII booster, 750 master,all new stanless lines.
INTERIOR- Sparco seats, steering wheel,pedals, shift knob,Auto power rollcage.
BODY- Carbon fiber hood/trunk lid,Carbon fiber front/rear spoilers,H4 headlight w/ HIDs, Vitaloni Sebring Mach 1 Mirror ,Euro turn signals.Custom steel rear wheel flares,Underside of the car is completly resealed and painted(I wish I could say the same for the top of the car).
SUSPENSION-Rear/ ProComp threaded andjustable shock, Front E30 M3 Koni 16way adjustable+Ground control threaded sleeve w/Eibach springs all around+GC camber plates,AKG Motorsports solid rear subframe mounts+lower strut spacer,Ireland 22m Sway bar kit+ all Polyurethane bushings,Boxed rear trailing arms.
WHEELS- Custom Ordered offset SSR Professer2 Fronts-8.5X16 Rear-9.5X16photobucket/robdaehn3
  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Nice ride indeed , hope to see it finished soon :)
about the suspension , what front suspension are you running exactly ? E30 M3 full wishbones and so on ? (M3 E30 are 5 lug) :)
-Living in the wrong side of the world ..
Cheers
Chatroom John
Hi JohnV, I used the stock 2002 spindle, weld the spindle to a custom tube which is same circumference of a E30 M3 shock insert, then I used a Koni 16way adjustable shock insert.
nice idea , how high does it sit compared to stock height ?
regarding the brakes , with a E30 pedal assemmbly , isnt there any possibility to fit a Golf Gti brake booster for example ? (will be slimmer and clears more room) , and of course more pics , sir !
Thank you,
John
Cheers
Chatroom John
New shock height is an inch and half shorter then stock. The GTI booster can be used, in fact I considered a GTI booster but after looking at the two(2002 booster) both are very similar. The reason I chose the 2002 booster, 1-because it bolts straight to the e30 pedal assembly(after bracing the fire wall) 2- If you are considering larger brake you will like to use a master cylinder from a 750, it will bolt right on to the 2002 booster. For the pic's....I will post new photos as soon as I get the car back from the electrician. Thanks for taking interest in my project.
