Sunroof question
jrags8
All:
Been around BMWs as long as I can remember, both on the road and on the race track. I have recently decided now is the time to restore a 2002 and picked one up a couple of weeks ago.
The sunroof on the project car opens, but scrapes the roof, which I think is due to the rust on the roof/seal adjustment. I can't get it closed all of the way now, but it raised a question...my old 325es sunroof opened in two directions - the whole roof would slide to the back, or the rear would go up 2"-3" to "vent" the interior.
Does the '76 2002 do this, or does it only open with the whole roof sliding to the back?
Thanks.
Jim R
Jim R.
as for your scraping sunroof, check the archives--there are several posts on how to adjust the sunroof panel's height so that it closes properly without touching anything.
If you can't find the postings, drop me an e-mail in a couple of days--I did a column on removing/replacing sunroof panels and how to adjust their fit some years ago in the Roundel.
DOes it scrape the roof when closing or when shutting?
If it flips up when you're trying to close it, then most likely the spring tabs on the underside of the panel are not positioned correctly, these are what make it pop upward, fully closing it, when it hits the front opening. They create resistance to the roof flipping upward when you crank normally.
You can verify by opening the roof about 2" or so and popping the front edge of the headliner piece down and sliding it rearward.
Matt McGinn
Sports Car Restoration
www.sports-car-restoration.com
1974 2002 turbo 4290909, resto project, looking for parts
89 M50'd e30
72 Alfa GT Veloce
84 M491 911
68 1600 channeled and flared project
70 2002 flared car project
It does it both when opening and closing on the top of the roof, takes the paint off down to the primer. My thought was to try to adjust the height as mike suggests as I would like to avoid removing the headliner.
Jim R.
