tii clock in non-tii 02? opinions needed.
Hugh
I have a spare tii clock.
Would you cut open a good condition dash to install a tii clock? I suspect I'd need to use a holesaw and drill a big honkin hole in the dash.
I'm leaning against it. Has anyone ever done this before?
» Hugh
» Early 71 '02
Yea, I did it, but did not use the tii clock. I used a modern VDO 2" diameter clock in the stock tii location. It came out great!
I had to fabricate an angled spacer out of black PVC to take up the space between the face and the dash.
I don't have photos here at work, but I can take some if you are interested. Send me an email so I know were to sent the photos.
Good Luck,
Mike (#87)
I will take some photos and see if I can remember the parts. It has been a long time since I did it - 15 years or so.
If I do remember correctly, there is a depression on the backside of the dash cover that is in the same location as the tii. There already is a hole in the metal structure behind the dash itself.
I think I connected to the wiring from the instrument cluster for both constant power and lighting.
Good Luck,
Mike (#87)
i did it on my non tii 1976 dash.
there is indeed a cutout provided in the metal backing, so all you have to do is slide a exacto near where it supposed to be and follow the metal edge.
1985 XR4TI, 22psi ±300hp
It's what the factory should have done....added a clock to all 2002s..not just Tiis and Tis....Not sure if I'd cut up a good uncracked dash to add a clock..I'd rather put in a newer radio that has a clock on the display..but if you do not have a concern with originality go ahead. The only thing I would not do though, is use a Tii clock...most of them do not work at this point....Search ebay and look for a modern clock or better clock in similar style to the 02s gauges...I'm sure another car make had something similar..
'03 BMW Z4 3.0i
’89 BMW 325is
'80 Mercedes-Benz 300SD
'20 GMC Sierra 1500 SLT
tii clocks, VDO Hollywood for one. They put in a new quartz movement, you do not get the customary "clunk" every minute or so.
You can pick up power off of the back of the gauge cluster, I forget which lug, but a little work with a DMV, you can find it. That is how the tiis pick up power.
1972 2000tii Touring #3422489
FAQ member #5
