coilovers (shortened struts) and camber plates completed..
fdovargas
Hi guys, here is my coilover setup...
Steps:
1. Sandblasting and cutting the tii struts
2. Welding
3. Black powder coating
Detailed picture of coil over support, with interior center lip
4. Installing the ground control colivers for BMW 2002
Interior spacer for fit the VW rabbit BILSTEIN shocks
5. Installing the IE camber plates
The job is finished
Thanks for the help in the FAQ!!
Regards...
Hi Fernando,
Looks great!
Where did you get the piece that holds the coilovers in place? (see pic)
Thanks,
Maikel
Maikel, the piece was made in steel machined with custom dimensions. Below i attached a pic with the diagram for the FAQ people.
The image of the right side applies for ground-control coilovers, i'm not sure if Ireland Engineering or another brand has the same length.
  • 6 months later...
  • 3 years later...
Hi What rate and size springs are you using , how much did you cut out of the strut , Im about to do the same ?
72/2002 Inca
72tii/2002 "Apple"
70/2002 "Five "
73/2002 "Freeda"
2007 Lotus 7 Replica
2011 Ford xr6 Ute
85 E30 325
70 1600-2 "Orange"
