What's the weak point of the M10 motor?
Pinepig
wHAT DOES THAT MEAN LEE? IVE NEVER HEARD OF THAT.
On the top of the block, around each hole, a 0.04" x 0.025" square ridge is cut, and in which a 0.04" stainless steel wire is inserted. 0.015" will portrude above the deck, applying a very localised pressure on the headgasket, or more precisely against the steel rings in the gasket. That will seal the combustion chamber for good. It is a very common method used by shop who works on Turbo engines.
Brake harder. Go faster.
  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
Take a look in my blog page for the current intake setup. It's an early 320i with a Honda TB off a Prelude, bore is 57mm. I'll end up switching to 42# injectors instead of the current 24#ers in there now. My buddy has 42s in his Audi 1.8t and makes 360 something to the wheels ( all 4 ) now.
I'll probably make another A/W intercooler as it makes the piping so much easier. Side extension for the oil pan and a some anti slosh panels in there will also happen. If it takes welding I'll do it just because I like to weld things up. Heaven help me if I ever get my hands on a Bridgeport.
For you guys that like the TDI my buddy Howard has the fastest MK4 in NA right now ( Atomicsushi for you clubTDI folks ) It's getting a motor swap at the moment because he's never happy.
I took a look at your blog.... LOVE IT! You just made my day with that TB discovery. Do you know what year?
For Clutch/PP you can probably use an M5 Clutch, an S14 M3 clutch or many guys use Volvo or other types. A friend told me once that he feels it bizarre that BMW owners insist on staying BMW only with parts. He suggested looking at it differently - like there's a company called Sachs. They make clutches & PPs for many different applications. It just so happens that BMW chose some of those applications - but so did many others. I'm sure you can find something BMW for your application like out of an ///M car.
Best of luck again & keep the pics coming. (O-ringing a block costs ~$25US per cylinder... Bring the ring with you or have it done by the guy who sells the ring)
E36
