m20 powered 74tii
powelli
looks good ian, what are you doing on the inside to reinforce the tranny tunnel for those tranny mounts if anything? im was thinking large fender washers but perhaps something beefier is needed. any comments??
im not thrilled with the thin gauge metal my tranny brackets are made of. yours are twice as thick
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
  • Replies 145
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I believe that he welded large washers to the tranny tunnel. Will have to check it when it comes down from the lift.
My mechanic dabbles in fabrication work as well. It was his idea to build the stiffer brace. If you look at it, the horizontal piece actually has a slant to it. This was done to allow him to add a second mount on the left side beneath brace and tied to the tranny via a bolted on bracket. I'll try to get a pick of that as well when I return to the shop.
  • 3 weeks later...
Windy day for pictures today......
Exhaust fabbed last week. Requires some adjustment in the rear as they didn't leave enough room for the gas tank to drop in. Goes back to exhaust shop on Monday for slight modification. Seats are being done by T&C Auto Upholstery and they are coming along nicely. Hope to hear it fire in a couple of weeks.
Edited by powelli
Addition of pics that were deleted when hosting site closed
Interesting to read that. I went last year and had a nice time talking with Jonathan (jgmgti), John (John_in_VA) and others while I was there. I took lots of pictures of Juanita and others to use as reference for when I put mine back together.
Yes, mine might fit in well once it is completed. However, my intent is to use this as a fun driver/ occasional show car. While the DM is a nice date to shoot for completion of the car, I am really looking forward to getting out and going on one of the fun runs with the local group.
Thanks for the encouragement and for the inspiration.
  • 3 weeks later...
Wiring almost completed....still needs to be tucked up cleanly.
Should probably update the relays...
Cooling hoses in...had to be creative in some spots.
Tight fit....radiator is firmly mounted and sitting on poly mounts so there should be no contact with the engine.
Driveshaft back in place...
Shop should be focusing on fuel and brake lines this week.
Edited by powelli
Your making great progress here. I really cant wait to see it complete - It will look absolutely stunning and I bet your hanging out to drive it! I think the red was a great choice too...
72tii - Whitey
74 - Blacky
Are you routing brake lines in a new direction, or do you have pre-bent?
I only ask because it looks like its going to be a tight fit to work around with the engine already in place!
By the way, what are those bars zip-tied to the radiator?
click signature above for my resto blog
