Horn at steering wheel
bobbo
Clean your brass slip ring and make sure the button has a good contact.
That button should be spring-loaded. Check to see if it is gummed-up and sticking.
Is your horn relay tab #86 energized when the ignition is "on"?
If so, then check the ground continuity through the steering wheel.
Edited by John76
Correction
Looks to me that the carbon brush and holder is installed on the wrong side of the wheel it needs to be pushed into the ring to make a ground in the picture it's just floating.
George S Patton
That harness is missing one more set of connectors on the wire from the carbon holder that my original harness has so the only the carbon holder wire has to be fed through the hole from the back side.
