Clock light stays on after engine is off
RJT79
Hello,
can someone shed some idea on why my dash clock light stays on after engine is turned off?  It’s a 74 tii.  And should I pull the battery off so it won’t kill the battery?  I drive it about once a week.
Thanks.
I'm guessing that someone, after removing the clock, somehow managed to allow the wire that illuminates the clock to be in contact with (or was swapped with) the wire that powers the clock itself.
The clock has to be "hot" all the time; otherwise it would never  show the correct time if its current was switched off whenever you turned off the ignition.
The clock's light, on the other hand, is wired in with the lighting circuit, so it goes on and off with the parking, tail, headlights and dash lights.
Here is a pic from E-Bay.  Unless the wires have been altered, it is hard to have it connected wrong.  Positive connector on the clock is male, ground on the clock is female and the bulb holder is directly connected to the wiring harness.
Karl B.
2003 330i ZHP 6-spd
2011 328i xDrive
