Swapping long neck input flanges
offsubject
I am in the process of replacing a broken long neck diff from my 1968 '02.  Given that the long neck diff in NK/1600-2/2002 came with two styles of input flange (three bolt w/guibo and 4 bolt with u-joint), is it straightforward to pull an input flange from one and place on another? Or does that involve cracking open the diff to replace things like crush washers etc. Would make sourcing a replacement simpler if not constrained to one type of input flange and can simply take the flange from my broken unit and swap it over.
Thanks!
https://www.bmw2002faq.com/articles/technical-articles/history-and-reference/bmw-2002-service-repair-manual-r247/?tab=comments#comment-1382
and then read down to where it says
...so, yes.  the flange is not part of the pinion stack,
like it is in the shortneck.
