Looking for guidance on 32/36 throttle linkage
jaredmac11
I'm attempting to set up my linkage on a 32/36. I believe the Pn is 35411103814.
  The throttle rod leaving the linkage seems to be clocked at a 10 o clock orientation when photos I've seen seem to be 2 o clock.
In the photos below,
Golf is mine, everything else is a friend's.
I am happy to try and modify mine but I would prefer to not hack up a harder to find part if I am doing something wrong.
If I flip the u shaped lever 180, the rod points to the 5 o clock position. Neither seem ideal and sort of bind.
Do I have the wrong part?
41 minutes ago, John76 said:
Contact @halboyles at Only 2002 if you need linkage parts.
Thank you for that mention @John76.
We actually have complete downdraft linkage kits to replace all the worn parts on the originals.  See it here:
WWW.2002SONLY.COM
It’s finally here! The Ultimate Downdraft Linkage System for your 2002. The System replaces everything from the firewall to the Weber carburetor’s throttle shaft! Throw away your 45-year-old, kludged-up downdraft linkage and replace it with our more robust, more responsive and...
This is a bolt-on system and works with both the 32/36 and the 38/38 so you have carburetor options.
Edited by halboyles
BMWCCA  Member #14493
www.2002sonly.com
Just installed Hal's throttle linkage. I'll have to post some pictures of my badly worn linkage. I never would have guessed how much of a difference it makes to have a tight and properly functioning linkage. Seems like a bunch of nagging carb issues vanished with a linkage refresh.
Yes, please do and thanks for using our linkage!
Everyone is surprised just how badly their downdraft linkage works until they install ours.  The pedal response is instant.  There are no dead spots.  The movement is incredibly fluid.
The existing linkage mechanisms are around 50 years old and virtually none of the replacement parts are available.  Here are some pics of the linkage parts we typically find on the downdraft 2002s that we work on.
Edited by halboyles
www.2002sonly.com
Put the pedal end in the viSe,
grab the carb end with viSe grips.
and give it a 90 (or so) degree twist.
Done!
My theory on the smaller, springier bent rod design is that while it also saved money over the
more high- tech- looking Mert-cedes looking part, it really saved wear on the
carb, by flexing when the engine moved under full throttle and jammed the carb
more than wide open.
has done this a few times.
Looks like I'm trying to use a hodgepodge of linkage for mine. I don't seem to have the standard 32/36 but hearing Hal mention I could lose the dead zone of the throttle is enticing!
I can feel a gap in the throttle when the 32 is opened and the 36 is opening.
I'll reach out to you, Hal with some other questions!
In the mean time I was able to cut, modify, and weld a new linkage. It just needed to go over 25, degrees from the 11 I clock to a 1 o clock position.
