Mark92131 Posted November 7, 2022 Share Posted November 7, 2022 I was doing some test fitting of the motor mounts for the S14 swap. I have the rectangle shaped driver's side motor mount with a cylinder-shaped alignment tab on both mounting surfaces. Do people using this style just cut-off the outside alignment tab so the stud will reach the bottom of the mounting bracket. With the outside alignment tab present, the stud seems too high in the mount and the motor will sit higher on the driver's side. The round E12 version from IE only has the alignment tab on one side. Mark92131 Quote Link to comment Share on other sites More sharing options...
jimk Posted November 7, 2022 Share Posted November 7, 2022 The subframe side is modified wrong. If correct, the mount bolting stud will protrude thru enough that the alignment stud will fit in the notch, 1 Quote Link to comment Share on other sites More sharing options...
Solution TobyB Posted November 7, 2022 Solution Share Posted November 7, 2022 My vote- rotate the engine mount so that the alignment peg drops down into the slot. Then see how far off vertical the engine mount is... From that picture, I can't tell exactly which way's up- the subframe mount tilts backwards, so the alignment peg on the rubber engine mount's offset so that it sits at a right angle to the engine, and thus has freedom of movement in the right axis. t Quote Link to comment Share on other sites More sharing options...
Mark92131 Posted November 7, 2022 Author Share Posted November 7, 2022 17 hours ago, TobyB said: My vote- rotate the engine mount so that the alignment peg drops down into the slot. I was assuming that the orientation of the motor mount was in alignment with the subframe mount, but apparently it sits at a right angle when the peg is engaged in the slot. Thanks Toby! Mark92131 Quote Link to comment Share on other sites More sharing options...
M3M3M3 Posted November 7, 2022 Share Posted November 7, 2022 leave both inner and outer engine mount nuts loose until engine is in the car and settles. locite and tq the metal mount bracket to the engine before the engine goes in. 1 Quote Link to comment Share on other sites More sharing options...
