Question about choke linkage, Weber 32/36 DGEV
Paulo
Go to solution Solved by TobyB,
Is there supposed to be some sort of circlip on the end of the pivot shaft of the butterfly valves to hold the choke linkage to the pivot shaft?  Mine is coming loose, and I think it's a reason I've been having warm start problems.  Thanks for your input!
If there's a hole in the rod, it uses a tiny cotter pin or hairpin clip.  Lacking either, it was originally staked to the choke butterfly shaft.  If it's coming off, you'll either need to re-stake it (punch the end of the butterfly shaft to deform the metal, or remove the shaft and either drill for a cotter pin or groove it for an e or c clip.
  • Solution
Yup, as Mike says, if there's a hole, it gets a tiny hitch pin,
and if there's a groove, it gets an e-clip.
Those e- clips are infamous for flying off and taking a dive
in the neighbor's pool, since you have to disconnect them
to get the lid off the carb.
Many thanks, Mike and Toby.  The shaft on my carb has no hole, and not enough length to drill one, or for an e-clip, so I was able to stake the end of the shaft with a cold chisel.  Worked perfectly!
