Rocker cover nut tightening sequence
8 ft/lbs max but most say be careful and if it feels tight don't go further. Also tighten in a couple stages. I used a couple copper crush washers under nuts since some of my studs sat high and I did not want nuts to bottom out. Also dont forget a small dab of your favorite goo under the gasket where timing cover meets head. I use Hylomar Blue
1975 - 2366762 Born 7/75
See the whole restoration at:
The heads are prone to cracking near / above cylinder 4. Clean that area thoroughly and check the thin "vertical" area of the head casting near that rear-most stud for stress crack(s)
Paul Wegweiser
I've always tightened my valve cover nuts like head bolts:  begin with the center two, then crisscross the outer four, ending finally with the bolt at the very front.  But regardless, they're still gonna weep a bit.
If you're not the original owner, you might want to check the valve cover for flatness by laying on a sheet of plate glass, or using a straightedge to make sure it's not warped.  If it is, a machine shop can skim it to get it flat again...
I’ve had this one about 13 years, I think I’ve done a crap job of tightening the cover, I reckon I went around the perimeter and not Criss cross, I seldom do things like that?, it was the end of a long day putting it all back together after a kugle pump swap out, because it’s above #4 plug it leaked onto the exhaust down pipe, though I did stem the leak a bit tightening it down, but did not manage to stop it, the cover is flat as I had it on a bench, but I will also check the head for cracks, looks like I have a job for today?
Thanks all.
I understand some valve cover gaskets are thinner than others, possibly causing the nuts to bottom out on the studs (top out?) before they are properly tight.
Ray
