Seat FoldingIssue
PeterCS
Lots of spare time so I am determined to fix this vexing problem.  My seats fold forwardcrookedly!
I mounted the seat on my bench.
All was good until I used the recline knob to change the recline.
They then folded forward crookedly ... again!
You can see from the picture that the angle of the hinges is different which must be the problem.
Should they be at 90 degrees at folding?
Thoughts?
Peter CS  (74 BMW Inka, 82 315 Baur, 2012 135i)
Stay safe and well and thanks as always.
If you had the hinges off the seat as Hans mentioned above, and the hinges came loose from the torsion bar that connects 'em, that's your problem.  It's definitely not intuitive, but the hinges must be reattached to the torsion bar so they are not parallel to each other.  I found this out the hard way when I was messing with my '73's driver seat.
PM me and I'll send you the column I did on the subject.  This is for roundie seats only; I don't have any experience with this problem on squarelight seats, but it may be true with them also.
Mike - I tried sending you a message via this site but it says that you do not receive messages.
I did remove them and reinstalled them at the same angle (parallel).
could not find your article. How access?
many thanks, PeterCS
Hi Peter
Pls PM me again--my inbox filled and I had to delete some old messages.
