Window trim question
Barney
Hi all... there are two pieces of window trim that I haven't been able to find (on Blunt Tech).  One is the external vertical strip behind the column (rubber) and one is the internal vertical strip in front of the column (rubber with foam).  Picture attached.  Any help to locate these is much appreciated!
If you're referring to the seal that's fastened to the B pillar and seals against the trailing edge of the window glass, it's part of the perimeter door seal, and AFAIK isn't available as a separate part.  You have to buy the entire seal,  And that vertical piece is a single piece; there's no "outer and inner."
It would be a Good Thing is someone reproduced that piece by itself, as 90% of the time, it's the only part of the door seal that actually deteriorates, as it's the only part that's always exposed to the sun.
Someone please advise if that piece is available separately from the entire door seal; I need four.
  • 1 year later...
