Call me a FENDER, FLARE, NUT
conkitchen
I
HATE
NUTSERTS.
(credit to RIMSPOKE)
I have never had them work well, and
I've tried everything from cheap Chinese
to crappy Korean to well- made European.
I would MUCH rather drill out an aluminum pop
rivet than a spinning nutsert.
That said, I always WISHED they'd work...
...and I resemble that color.
used a lot of pop rivets last time
Needs to take a mold off them, as
the last version seems to be unobtanium now.
The one challenging thing with the nutserts was to maintain alignment to the flare's pattern.  After installing each one (nutsert) I would bolt up the flare to check the alignment and make minor corrections to the pilot hole for the next insert. Had to hog out a couple holes to bring the next one into alignment for the bigger bore.  I did have a couple go badly and drilled them out and installed another.  Over all, I like it best as I can remove the flare in minutes to clean and or prevent damage when working on the suspension.
The rubber gasket "welting" is key to a nice finish.
but what do I know
Just to add more details. I am using stainless steel hex head machine screws which look much more space-age.
Edited by conkitchen
But what do I know
I have a set of original Turbo flares I'm debating of putting on my 68 when I get around to paint and body work but my body is clean and rust free I'm having a hard time deciding if I wan't to chop it up
Please no turbo flares on a roundie.
rtheriaque wrote:
10 hours ago, conkitchen said:
I vote maybe
My car is a tii, so some might say it's now ruined.
What did you say?
Ray
