Half axel boots ?
Road trip
Walloth and Nesch has them, if they are in fact the early opaque type.
https://www.wallothnesch.com/en/hinterachse/bmw-1500-2000-tii-4-tueren/katalogbild-33-10.html
Do a search here for the technique using boiling water to soften them and then a spoon or similar to stretch them over the pin.  I would never have believed it would work until I did it.  Also, don't loose any of the 144 bearing needles.
Bill
1973 3.0 CS Nachtblau
1970 2002 Chamonix
1965 1800 Chamonix
Boil the buggers. Spoon or metal shoe horn  works to get it over the post.  Test for leaks before you install on car. Oh, and wire brush half shaft where boot sits. BMW used to sell O ring for mounting hat; or go to local bearing shop and see if they can make O ring to correct size. Silicone works in a pinch. Be very careful with the clamping ring. I finally found asymmetric CV joints and will donate my early halfshaft collection to charity.
Edited by Hans
