Getrag 245 5 speed and tii brake booster
Wgmack
Thanks.  I have seen similar write ups, I just couldn't tell from your picture what was included in your sale (mostly my fault as I am not a mechanic, so don't know exactly what I am looking at.).  I guess I am ultimately trying to determine if I will need to spend another, $100, $500, or $1,000+ to have all the necessary parts for the swap.   I'll try and do a little more research to educate myself.
'73 Riviera Tii
'93 M5 Dinan stroker, etc...
'08 M3 ESS 625 s/c'er, etc..
'64 Stingray
  • 3 months later...
1 hour ago, germancarguy said:
Just an update, the transmission was installed and would not shift. When dissassembled a broken bearing was found and a roller was jamming the shift forks. To make matters worse the bearing is unavailable, would you happen to have any transmission parts ?
Paul
I believe BMW of south atlanta has the bearings for the 245.
This link has tons of 245 information and pat numbers: http://www.bmw2002.net/pdf/Getrag245.pdf
Edited by ohgodno
added link
They (nor does any new parts supplier) have any new ones.  This is when MM and a few others start machining the box to fit a new dimension'd bearing.
Unfortunate situation, but not unheard of when dealing with used (ie core) parts.  Best of luck Paul, hopefully the original poster will offer some sort of partial compensation.  I'll be watching to see how @Wgmack handles this.
Edited by AceAndrew
I spoke to Paul, the purchaser of the transmission, this morning.  I offered to make it right and I don’t think there are any hard feelings.  It sounded like he had a potential lead on a bearing from Europe.  I will be checking in with him again.
-Will
