Front Alignment Specs
rstclark
6 minutes ago, AustrianVespaGuy said:
... then I'd be reasonably confident that the cause lies elsewhere (camber, caster, rear alignment, brakes, or frame. . .)
Dead bushings, bent bits of metal...
Dave.
Thanks @uai and @AustrianVespaGuy - car has following modifications from stock:
Front
Bilstein HD inserts
IE stage 1 springs*
IE strut mounts
IE sway bar, billet mounts, urethane bushings and new links
New radius arms/rods and hardware
Rear
Bilstein HD shocks*
IE stage 1 springs*
*only these were installed by my mechanic recently, after which the issue of randomly veering to either side started happening.
From reading this thread I understand that camber and caster aren't adjustable with stock domes unless I add specific top mounting plates.
Car veers without braking, so I want to rule out imbalance brake pressure for now.
So, I guess, step 1: take it back to mechanic and have him fix the toe on both axles, then take it from there?
