What And Where Does This Relay Belong
Koblenz
My turns and flashers work but the blinker indicator is intermittent at best.
a very easy and inexpensive fix to your blinker issue is use an off the rack electronic flasher...2 of my cars had the same problem, i read about the elect flasher when i was hooking up lights on the 69, bought 2 at autozone and no more blinkers with their own agenda...they blink when told now
Fantastic!  On the way.  I for one believe a indicator should speak when spoken to.
Is this the beast?
http://www.autozone.com/autozone/accessories/Novita-2-pin-12-Volt-1-to-20-x-25-Watt-heavy-duty-electronic-flasher/_/N-26fp?itemIdentifier=193118_0_0_
Edited by Koblenz
Is this the beast?
that one may work but the one most commonly talked about at FAQ and the one i used is this one...i got them at autozone and iirc, they cost less than $10.00 ea
post-9202-0-44016700-1402489586_thumb.jp
wired like this:
Black/White to the "X" terminal (12V power)
Green/Yellow to the "L" terminal (Load)
Green/Violet to the "P" (Instrumentation)
no ground wire is used or necessary
