mo02
Go to solution Solved by Beaner7102,
I am wondering if anyone else has experienced their turn signal relay flashing faster over time?
I purchased an old e9 with an extremely fast flasher relay, luckily I switched in a spare from my 2002 and it worked fine......for a while.
Now when I switch on the turn signal, I notice it is flashing a little bit too fast.
Is this a normal problem due to age and the car sitting over time? (worn/corroded contacts)
Or is my electrical system to blame ie. voltage surge, improper wiring etc...
And how can I fix the problem other than replacing the old relay with a new unit?  Are the relays adjustable or repairable?
This is just something I am curious about and would like to know if anyone else has asked these same questions.
Thanks in advance,
-MF
73 sunroof 2002 (past)  |  73 CSi (present)  |  FAQ Member #2538
2002 decals (mofaraz.com)     |     eBay
Thanks for the link, I can see there has been much discussion about this topic and I am amazed that a new relay would cost between 45-100 dollars!  A simple repair would suit me just fine.
I still have my old spare relay and may disect it to understand more, I will post pictures if I go down that road.
Cheers,
MF
  • Solution
