rpm changes when car gets driven
1971Ginger
So I've got a 008 distributor with a hot spark ignition. Engine was timed as best as possibke via timing light.
When I drive my car for a while, when I stop I notice my idle will fluctuate its rpm from 1000rpm to 1300rpm and up to 1500rpm. I know my distributor is tight and all sites have been looked over for good connection (I didn't run any volatege tests)
I was wondering what might cause this? I tried to set my air fuel mixture by rotating the screw on my 3236 and when turning the screw all the way in my engine didn't shut off. Do I have a vacumm leak?
I read PierreAlans. Posts about hot spark having a smaller dwell angles and thus I thought maybe its the electronic ignition.
Any advice would be appreciated.
1971- 02-Malaga -(Ginger)- 2nd owner
1973-02- chamonix (sold)
pardon any grammatical errors in my posts, im probably on my cell phone.
yes a vacuum leak possibly - something wrong
the carb mounting insulator block/gaskets/loose?
burned? or messed up intake manifold-to-head
gaskets, rotten vac booster hose, bad vacuum
brake booster, missing rubber square o-ring
between brake master cyl. and booster ?
if your distributor has a mechanical advance
plate look to it's free, not sticking movement
advancing and springing back retarding function
That sticking causes your irratic RPM behavior.
if your carb linkage from the firewall is binding
and causing the carb throttle to crack open -
then that would be your cause for irratic idle speeds
happy hunting
'64 R27 250cc #383851 18,000m
