Tii Fuel Pump Seal Advice PLS
I removed the brass outlet on the pump. There is a unique copper washer to seal it against the pump. Unfortunately the washer is dead, crushed.
I looked everywhere locally and can't find a supplier. Short of converting to a 5-Series pump, anyone know where I can get this copper seal/washer?
This pump is young and has years left on it, don't want to lose it.
Thanks for reading and replying.
73 Inka Tii #2762958
look at mercedes/saab/volvo/vw electric pump parts suppliers
for the seal ring you need ?
it should be just a common copper flat seal washer from
any metric bit supply bin
i know this isn't your pump,
but your looking to seal the fitting
at no.2 here ?
'64 R27 250cc #383851 18,000m
Yes, the outlet valve has the copper seal at its base. I tried local autoparts shops as well as BMW and industrial fittings suppliers.
I could find the right ID and OD but the thickness is greater. The valve bottoms out if the seal is crushed too much.
I'm not sure how to ask Mercedes/Volve/Saab for the part, if I don't have a # or reference to their pumps. Ideas?
We're essentially talking about a copper washer, right? I mean, buy the one that's a bit too thick and mill it down. Copper is soft...
Cheers,
Ray
Belt sander?
I did smooth the surfaces, but I'm sure the seal is crushed too much. As I said the valve bottoms out before a seal is achieved.
Ray
What I found is that the correct washer is thicker than usual. In my search I found correct ID and OD but too thin. Nobody that I found has a thick enough washer. Using a thin one, the valve bottoms out and does not create a seal.
Oh. Guess you need to reverse the belt sander. ;-)
I guess in theory you could use 2 replacement washers... but...
... something can be sourced, or made :-)
GL,
Ray
Ray
