2002ti wannabe project begins
jgerock
I'm interested to see how well-oriented the cam is at TDC (see Arminyack's thread). If you get to it this year.
:D :D :D
Ray
:D :D :D
I did not have to rotate the cam when installing the chain. The links were somehow lined up perfectly.
So, at TDC the notch on your pulley lines up properly, and the cam timing is correct?
Is this with a milled head and stock cam gear?
Cheers,
Ray
Cheers,
Yes - pointer lining up with pulley marks, bottom of cam gear has hole for Schrick button. Both lobes of # 1 cylinder down.
B4CF1654-28B5-473E-A410-EC18593F7819_zps
Picture of head with valve positions just before placing on the block
C7F0431B-11A3-439F-B410-AE242E14EC35_zps
C5D44E0F-4888-4985-B447-DCC887A6FB23_zps
3D3EA32B-7257-4A2C-86C0-400E6926C42B_zps
71E2A270-E44D-4956-8739-F076395D5182_zps
I have a timing wheel that I will use to check cam timing before going any further (if I can make it work)...
Head was cleaned up while at Korman's place.  New stock cam gear and crank gear.
Head and block "came" together.
Early single groove pulley sourced from local 2002 owner Dave R.
Turned the engine over clockwise to see the cam and rocker operation, adjusted the valve clearance (again), checked the torque on the head bolts, installed the tii exhaust manifold, the two ti intake manifolds and the new e21 coolant branch.  I purchased the reducer hose fitting for the water pump to return pipe but I need a straight one.  Need to order a new timing chain tensioner spring and piston (I have 3 old sets).   Am soaking the tii dipstick parts in Evaporust along with the distributor mount.
8AFADF80-0DAE-4BA4-83F7-B5F94E6C3057_zps
7E4951FC-FF42-48DE-9E58-C88DEAFD6A07_zps
D5A7DE8B-F992-497F-8C46-4FA9832839A4_zps
51E60C04-1F87-4ED5-965D-7D4E3237D5B0_zps
6BE5BABE-8494-4F6F-BA95-3B7114478DED_zps
Test fit a set of Solex carbs - think these are my best set so they will get cleaned up and new parts added where required
159E133D-F95B-4F79-AEE2-11D487225BE9_zps
E3B064C2-339E-42F8-A580-6E3944DE1587_zps
Emailed Blunt regarding E30 318 adjustable alternator mounting bracket hoping to use it with my stock alternator but from the pictures, the 2002 bracket is located behind the alternator tab and the E30 bracket is on the front so if I want to upgrade - I may have to get a different alternator.  The one from the 69 was an older remanufactured Bosch unit but squeaks when I spin it by hand.
Jim, I am not an expert on such matters, but I do have an E30 318i alternator bracket. I believe I had to order an alternator that was also made for the E30 M10-powered models. I am almost positive I ordered a high power, 95 amp unit from Blunt. I can confirm if needed.
-David
1972 2002 - 2577652 Follow the fun
Thanks David. I will see what I can come up with.
I wrestled with the front seats this weekend.   Started out cleaning the old dried up grease and gunk from the seat rails then reinstalling them back onto the seat bases.  I must have really messed up the pass. seat back when I worked on it since it was really twisted (inner side tilted back more than the outer side).   Out came the seat and I took the hinge off the outer side and reindexed the "torsion" bar what seemed like 5 times before I think it worked out.  What a PITA.   Bought some of these new rubber buffer pieces for the seat base tabs.
DC887C6A-BD1F-4817-B048-A9D51847DACC_zps
C4E02CBB-CF28-4159-B46B-7547D3A340AF_zps
When installing the seats, the new carpet made the inner buffer come right off the tab.  I may have to just glue a piece to the flat tab.
Color in picture is a little off- seats are brown, not yellow.
7F9E29C5-28A9-4E48-B4B6-94735C999AE6_zps
Now I think I know why BMW changed from the early seat rails to the later version.  The front tab hangs down and you must align the bolt hole before inserting the bolt.  Again, new carpet makes the seat rails sit a little higher and I had a hell of a time getting those front bolts installed.  The rear bolt holes are the same as the later cars.
Also glued up the rest of the door seals and installed the early type thresholds using a new rubber weatherstrip.  The thicker carpet made installing these simple pieces a chore.
I still need to find another black seat slider knob.
054CD990-2E57-4CD9-A124-F766C2517E49_zps
Reasons for not installing the door panels:
Need to redo the foil on the strips
Change the vertical fuzzy window channel to something that works (better than the stock BMW stuff)
Add the aluminum door topper trim
There are some things that really bug me when working on an old car.  One is that brand new parts from the original equipment manufacturer (OEM) do not work as well as they should.  For instance, the doors on the 69 have as many new parts as I could find to make them work "better than new".  I purchased new seals, trim pieces, weatherstripping, vent window trim, glass. window regulators, etc.  After installing new glass and the vertical weatherstrip channel the window would not roll up properly.  I had to pull upward with one hand while rotating the hand crank.   The new "fuzzy" vertical C-channel weatherstrip was very tight (I experienced this with my 71 VW but that was using aftermarket pieces).
Thanks to the earlier posting by Mike Wooldridge of Arkansas, I called the same glass shop but they referred me to another place down near the Tidewater, VA area...which referred me to another place, which referred me to a place in Lanham, MD.   After speaking with multiple folks, I ended up ordering some weatherstrip from a place in Canada who would actually ship it to me (rather than having me drive a while to pick it up after they ordered it).
Link to Mike's thread: http://www.bmw2002faq.com/topic/135132-mike-wooldridge-1973-chamonix-2002tii-clone/page-5
Purchased from Hi-Tech Glazing Supplies in Surrey B.C.
Standard Products # AS1198-96     (the last two digits indicate it comes in 96" lengths).   Searching by ebay does NOT indicate the length.
After I pulled the BMW strips out of the car and installed the new aftermarket pieces, the windows now roll up and down like they should.
BMW part on the right
A3FDDC93-DA9C-4847-B31B-5DA21D6C5C45_zps
BMW part (after I removed it) on the left
927CAD48-5E54-4926-9B9A-B486128D5D60_zps
The 2nd thing I learned was that if you cut and installed the channel too long, it wouldn't let the window roll all the way up.  In my case, about 20" was the correct length.
82CA666E-9952-4308-A976-FA0D0ACC60CA_zps
F1B63434-D338-408E-AB1F-0BB3548E0924_zps
Many thanks to Mike!
Did a little bit today.  Got the fuel tank sending unit installed after snapping a good mesh filter on the bottom.
52400291-5C52-4CE1-B0AD-011122DB7AC1_zps
Cleaned and painted the 72tii valve cover.  The one from the 69 engine was nicked up from where someone had pried it off a few times.
Installed the two stock BMW engine mounts using new hardware.  Right one fastened to the subframe - left one on the engine.
Waiting on my small parts order from BLUNT containing timing chain tensioner and dipstick parts.  Hope to install the engine in the next few weeks.
I really like the way the original brown interior looks with the Riviera paint.
4F3EA2F9-BBF8-4E9E-9382-A839E5470BE9_zps
C1C789C1-F16B-4E64-A47A-DA949361DA64_zps
9A3D9C4A-7569-4299-967D-7353639BD739_zps
Installed new tii dipstick tube, connector hose and clamps (parts from BLUNT)
B20C4CD7-6331-48F5-9602-9F17E3F61D2E_zps
Installed new timing chain tensioner piston, spring and plug, then bled the piston
55CF100C-B0F5-48A3-B519-5C9E8AB447C6_zps
New piston on the right
34E0EA08-F197-4D16-8174-FEE5BDD1BEED_zps
New one closer to my palm.  Note the slight difference
8BFE592D-2E40-45C1-8DEB-0972F0AC8F8E_zps
Noticed a possible error in the Blue Book regarding the piston length
F353D4DD-C52B-4624-BD6C-BEA6604475C2_zps
Soaked the new piston in some fresh 20W-50 Castrol, installed then performed the bleeding procedure
F3459838-CB6A-4D70-82C3-C5F4F0B48525_zps
Attached the upper timing cover, new 5-blade fan and the old alternator
72AA8439-FA63-43D1-9CCB-3EE72750F53F_zps
0B08972F-EA8A-4A42-86DE-5886C0AF5D8B_zps
D080B0F2-20C7-4F95-9488-243AE509224C_zps
Attached the E30 318 M10 alternator mounting bracket and had to do some minor bending to make it work with the 2002 alternator
94E4AEEB-4059-41CD-B68E-89793B60DA72_zps
New lower bolt (pan head with square shank) is too long.  I tried a bumper bolt which will fit but is too short so I'll look for a longer one (about 50mm).
E3CD16B6-19A6-486C-B721-E3DB419BA412_zps
My old Bosch remanufactured alternator that came on the 69 engine squeaks and the shaft is sort of stripped so I will need another one.
