Master Cylinder Question
mrdew
I pulled this off of the master cylinder. I am rebuilding it, because I was unable to get the brakes to hold pressure, they would build it but not hold it. But in the process of tearing it apart, I found this. It has the rear brake line connected to it.
That is a residual pressure valve for the rear brakes. It keeps a little pressure in the lines for the rears only.
'69 2002
'59 MGA
'67 Chevy C20
“Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.” - Mark Twain
...and is not present on any of the cars I have owned or parted.
But I tend to do early cars.
And the BMW rear system does not particularly require it.
Well, that's funny- Marshall, are you sure you're not makin' that shit up?
Well, sumbeech, lookee here-
#04 PRE-PRESSURE VALVE 1 34314650332 $21.70
right on realoem, so it must be right! (another grin)
Wonder if I've just been missing it all these years (possible)
or if ALL of them were lost by previous owners replacing the masters?
That's HY- larry- ous.
ya learn yer an ijjit at least once a day.
LOL! it appears seattle cars and dc cars were made in a different factory... seattle cars had no brake press valve and used oil filter cartridges instead of spin on's! clearly i must avoid making generalizations when refering to 2002's! or just stop makin' shieet up! :-)
M
  • Haha 1
It helps equalize front to rear brake 'timing' The wheel cylinders have to overcome the spring pressure before contacting the shoes, while the calipers simply slide into contact. Leave it in unless you are converting to rear disc or very bad things will happen
1971 BMW 2002
38/38 DGAS
292 cam
TEP 4-1 header
Ansa Sport muffler
Bilstein Sports
H/R Sports
Full Urethane
IE adjustable sways
15x7 König Rewind
errr, bullshit. I've never run a car WITH one, and unless you consider
me on public roads to be a very bad thing
(which I could fully understand)
nothing bad has ever happened for not having it.
Ran the race car the same way.
Thing is, the rear wheel cylinders now have springs in them to
preload them against the shoes, and the shoes are held against
the drums by the adjusters, so all the slop's mechanically preloaded
out of the system already. And from what I've found, you really don't
want the shoes touching the drums much (at the track) or the rear
brakes start to bind up.
So maybe this thing was for rear wheel cylinders without springs?
huh.
Swinging into another corner of the German automotive front...
Sorry to bring the ol' VW into this, but some VW master cylinders (dual circuit type) have restrictor drillings in them and some have external residual pressure valves to help balance the front to rear bias.
Per the Bentley VW Manual for '70 and later Beetles and Karmann Ghias, cars with front disc brakes have a master cylinder with restriction drillings instead of residual pressure valves. These drillings are 3.5mm in diameter. Except for 1973 and later models, all cars with four-wheel drum brakes have residual pressure valves between the master cylinder outlets and the pressure lines (they look like hexagonal fittings). The master cylinders for 1973 and later models with four-wheel drum brakes also have restriction drilllings rather than residual pressure valves. These master cylinders must not be interchanged with those used on cars with disc brakes.
