Car runs great but horrible gas mileage
1974 2002 with rebuilt engine with only 3,500 on the clock, a weber, new tires. car runs and sounds great. i'm getting between 15-17 mpg. what gives? i'm thinking about cleaning the air filter (are k&n just as good as weber filter), and replacing the plugs. Could a dirty filter kill that much mileage alone? I'm confused cus the car runs great.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2000 Porsche Boxster
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
........what are your driving habits? + .......
and what you may think is a 'great running' car,
may infact be a grossly over-rich jetted carb.
got any idea of the jetting numbers presently inside?
Idle Jets =
Primary Main Jet =
Primary Air Correct Jet =
Secondary Main Jet =
Secondary Air Correction Jet =
Float Level mm =
even ignition timing has an effect on yer gas mileage
'64 R27 250cc #383851 18,000m
you aren't calculating your mileage with a groggy trip meter are you?
You should be betting at least 26 mpg I would think.
CD's all-over it - You should get your carb specs understood.
How about a video clip of your motor running? And pics of your motor?
Scott
...yup , 2002 or tii should get a nominal 25 mpg min.
during a 200 mile high drive - sustained 60 ...75 mph.
take it from there......
loaded road trip up to Waterville Valley, NH. way back when=
Worse than my 18-21... 21 is my highway right now. I need to check my carb numbers.
-Nathan
i'm getting 15-17 local traffic in LA. I took a look at the air filter and it didn't look too bad. I then backed off the idle speed screw and adjusted the idle mixture screw. I think the idle screw was opening the throttle a hair too much and maybe the carbs were a little rich. Performance-wise the car seems to ride a bit smoother with a little more power. Not that I thought it was so was bad before but I feel an improvement. After this tank of gas if I don't see an improvement I'll take it to a shop to get the weber calibrated. Has anyone in LA used top-end performance in north hollywood for repairs?
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
40-50 around LA, nothing too spectacular. rarely in stop and go traffic either.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
If u r going to use top end for just tuning I think they r alright. But don't trust them with anyhng else. Had bad experiences. If u want it done right check out the sponser page at socal vintage BMW. That's a good local list of. Mechanics who respect and love our cars.
Wow, thanks for the heads up.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
