BMW 1602 -67 M20B25 Turbo 525whp
oskarkronlid
Nice! Post up some pics!
A few questions, what did you weld on the head? Why not go with adjustable coilovers and increased negative camber after all that work to tube-frame the front of the car? I'd also like to know what you using for the diff, axles, and rear suspension.
I will now tell you the background story.
If I write kind of funny it's because I'm from Sweden
My BMW fascination started with my first BMW
A -98 that I bought -01
M Roadster 3.2l 321hp
It was a really fast car. The most impressive car I had driven before that was my mother’s Toyota Camry V6 so this was a step up :D
I also needed something to drive in the winter so I bought an E36 325 Coupe. Also a nice car.
In 2004 we built our new home so I needed some cash.
I sold both cars, but I still needed at least one car so we bought something more practical. An Audi S4 -99 Bi-Turbo 310hp 4WD, It needed constant repairs all he time
The S4 had to leave us and was replaced by a Volvo V70 not fun but cheap and practical.
But after a while I felt a need for something a bit more fun.
I found this 1600-2 -67
After some work
After a while I realized that if I ever wanted to drive I needed something a bit more finished so I sold the body stripped of everything that I had restored and bought this instead
It was just a rolling chassis
As I had already restored the struts on my old car I replaced the ones on the new car
Old struts
My restored struts with Bilstein shock absorbers (Newly produced from the specifications of the old 02 racing series in Sweden ) & H&R springs. Volvo 240 calipers, vented discs and hub from e21
Did not like the hight even though the springs were supposed to lower the car 40 mm.
I decided to use the old shorter springs. They were so short that they fell out when I lifted the car so I welded a piece of pipe to hold them in place.
End result
That’s the right hight
Building the rear end.
Removed the welded diff
Replaced it with a LSD from 320is
And combined driveshafts from e21 with 02 outer flanges to make them fit.
We will see for how long it lasts
Mounted
Anti roll bars from Ireland Engineering
Some speed parts arrived from PPF
Precision SC62
and a Tial 38 wastegate
I've modified the oil pan with a hose connection for oil return from the turbo, and an oil level plug since the side where the dipstick should go has been cut off to make the engine sit low in the car.
Painting some parts
Earlier I've painted some parts in Laguna Seca since my original plan was to paint the car in this color.
Test mounting the turbo to see where to weld the wastegate
Engine parts painted and assembly begins
Engine looking good :D
My daughter helping out
Bought a Nuke fuel rail from PPF and used injectors from Avvah
Started by cutting in my newly painted intake manifold
Made some brackets for the fuel rail
The new "Blackline" series
Improved ceramic clutch, 618 pressure plate form Sachs capable of 700nm
Mounted the engine in the car
Threw out the exhaust manifold from kina and replaced it with a high quality exhaust manifold from PPF heat coated
Made a boot floor out of aluminum and started laying out the fuel system
Aeromotive Eliminator capable of 700hp on ethanol
New exhaust in place
Also got myself a blingbling alternator
Mounted PPF fuel filter
I placed the fuel cell a little higher than the fuel pump so it doesn’t suck air.
Brackets for intercooler and radiator
Built some pressurepipes and downpipe
Brackets, pipes and hoses for the brakes
I have two sets of wheels, can't decide which to use
White 17"x7.5"
or 16"x9"
I bought a very nice exhaust manifold form PPF but I decided to go for a bigger wastegate, a 46mm Precision so I had to make some modifications
Connected some instruments
And now the engine has been started
Still some things to do before it’s on the road. I'll keep you posted.
I vote for the 16x9's.
About the diff, that e21 will last you about a day at 500whp. My friends blew up an open e30 small case(same size) in a week at ~350whp. I know how much it sucks to keep putting a project off, but considering how heavily modified your car is already, sell the e21 diff and get an e30 rear end with medium case diff. Swap that whole setup in(trailing arms, subframe, diff), it's not bolt on but it should handle the power for a while at least. 500whp is getting mighty close to large case diff territory.
You are probably right but I will see what breaks first.
I still have the welded diff sitting in my garage so that is always a temporary solution if the 320is diff breaks. And an extra gearbox.
The plan is to swap the entire rear subframe and diff to the one from Z3M or a M535 diff with "sviktstål" axels. I don't know what its called in English
but direct translation would be flexsteel. Its axels that’s capable of twisting 1.5 laps and flex back without breaking. It really saves the rest of the drivetrain.
And a gearbox from a 5 or 3 series tds then it's good for at least 800 hp.
But that will have to be next winters project...I hope ;-)
  • 4 weeks later...
Now I've been at PPF in Avesta Sweden. The engine has been tuned by Andreas at PPF. The car was placed in the Dynapack to see how much power I have on the wheels.
Result: 525whp and 686nm of torque (505lb-ft) approximately 600hp at the crank.
Thick lines are at 1.5bar (21,76psi) of boost and the thinner lines at 1 bar (14,50psi) of boost
Holy Cow!!! That is a LOT of power in a car that weighs that little! Very sweet car man!!
-Nathan
Amazing build! Keep us updated!
Personally I think 500hp in an '02 may be rather dangerous. But maybe I'm just getting old. :-) Please be careful with it!
Cheers,
Ray
Ray
