gwb72tii
Help pls - Windshield Gasket sealant
headed to the store in a minute
installing windshields - what do u uses for sealant when installing the gaskets?
- a mastic is specified -
I know what the manual says. If you want a big mess, follow the manual.
I have installed many windshields without any sealant and never had a leak. You should have no problem at all with a new OEM seal without sealant.
If you do feel that you need to use sealant, here is what the pro's use.
http://www.autobodytoolmart.com/showproduct.aspx?productid=10389
W. B.
thanks
i think we'll go without and do it ourselves
i've had front and rears on 2 cars installed....never used any goop and have never had a leak...
No goop. Make sure you use a genuine BMW seal that has the extra flap to cover the top edge of the dashboard. The "chrome" lockstrip insert will spread the gasket apart when installed.
You are commenting as a guest. If you have an account, please sign in.
  Only 75 emoticons maximum are allowed.
