Pesky transmission leak
BillWilliams
I have an e-21 CR five speed transmission with a pesky leak. It is around the shifter block and reverse light switch. The reverse light switch on a CR is where it is on a four speed, sticking horizontally out of the rear of the transmission.
I took the switch out, put a new crush washer and a rim of sealant around the very front of the threads. Using MTL Redline Transmission Fluid.
It still seeps from somewhere in that area. The cap bolts on the shifter blocks are less than two years old.
Can a seep come from that bolt and block? If so what can I do to defeat the seep? It is torqued to real tight.
Thanks, I did a search and promise to post my victory or defeat.
1972 2000tii Touring #3422489
FAQ member #5
Bill, I,ve seen new reverse swtches leak from the area that the plastic isolator persses into the nut portion of the assembly.
Also, good old thread sealer on the shift tower block bolts may be needed.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
Ditto on the switch itself leaking (not the NPT threads). If you can wiggle the (2) spade terminals, that is a clear indicator you are leaking from the plastic portion. Also, when you remove the switch, push the plunger in to see if the terminals move.
I put a new switch in using a copper washer - so far no leaks from that point.
is coming from further back than the plastic isolator but I will verify next week.
I will pursue the thread sealer. I guess you are saying those bolts go into a passage where transmission fluid is?
In the next two weeks Otis and I may be doing a little work on his car and he has access to a lift. Good time to remove the shifter block bolts and put some thread locker on them.
Thanks!
FAQ member #5
Bill - not sure on the CR 5-speed box, but the Blue book mentions the output shaft seal needs to be recessed about 2-3 mm into the cover. If it is flush or sticking out, then the driveshaft coupling will rub against it, causing a leak over time. This is exactly what happened on my car.
Damn, good info. I never heard/read of this.
I'm going to check it out(in the blue book).
Cris
Proud member #113
The rides!
Hi,
hey bill i have seen this before and what
i found out from my friend who works at
the dealer is that the tailhousing is designed
to handle 4 or 5 seals over its life time
before the case needs to be opened. so
get another shift selector shaft seal and
install it directly over the old one. also,
do set it in 1-3mm below the edge of the
case.
good luck
stone
stone racing co
phila pa 19123
