To buy (or not to buy) a rebuilt head... Advice?
CutteRug
Hi all,
My car runs okay, but when I come off the accelerator on a downhill slope, or there's ever any substantial back pressure (like downshifting into those second gear turns, hee hee) I get a LOT of smoky oil smell..
I've been told that my valve guides are going bad. So here's the question.. There's one listed on craigslist for $250..
http://sfbay.craigslist.org/sfc/pts/944620869.html
Is that a good price? Is there anyway to check it for being rebuilt or machined *properly*? Is a new head even what I need? Will it still be ridiculously expensive to swap them if I buy this??
Okay, that was more than one question ;-)
Thanks for any input or expertise any of you can shine on this subject.
Adam
(==\___| SQARY02|___/==)
1975 Millie the Falcon (Originally Polaris, currently Primer-Grey/Spa-Blue)
1975 Eamon the Golden Nugget (Originally Golf, currently several other yellows, someday Dakar)
Is there a reason you don't just have whatever work your current head needs done? I needed valve work done not long ago and got the valve job, a couple of new valves, all new guides and seals and a gasket set for about $530. More expensive clearly, but it was what my head needed, and it was covered by the machine shop if anything wasn't right.
Steve E.
www.theportabledad.com
1974 Sahara 2002
1974 R75/6 (Sold!) :(
This is a fertile land, and we will thrive. We will rule over all this land, and we will call it…This Land
I guess I'll try that... It's just that every time I talk to my mechanic, he only seems to be able to talk in numbers like *one thousand* or *two thousand*.. He's a great bimmer mechanic, but has gotten spoiled and no longer relishes the "bargain-seeking" 02 owner.. (like myself)
Didn't think a redone head would be so affordable... (and didn't think I'd ever be referring to prices over $500 as affordable ;-)
Anyway, thanks! I'll ask him about it next time I'm down there.
I would buy the head, but I just think that way.
It's cheap enough that's it's almost worth the gamble
sight unseen.
Before I paid money, though, I'd measure it (129mm is about stock thickness)
and put a straightedge on both the top and the bottom.
And look at the cam, rockers, etc if included.
Ideally, I like to evaluate heads with the cam loose- if the cam's easy to install
and turns freely, and the thickness is 128.5mm or more, it's almost always
a winner-
if there aren't any cracks... So if it doesn't include a cam, that's
almost better, since you can pop one in and give it a quick spin.
(I've found that a little friction's ok, but if you can't turn the end flange by
hand, then it might be best to try again somewhere else)
And around here, new guides and a valve job on a loose head tends to run in
the $6-700 category.
Excellent! Lol...
It'd be great if everyone said completely contradicting things, so I can end up even MORE confused..
Just razzin. Thanks again guys. In life there is rarely a simple answer or consensus.
Cheers,
Adam
Bill Arnold in San Rafael... (and I may have exaggerated a bit on the multi-thousand dollar quotes.. But he's not cheap)
Cheers,
Adam
oog.
Me being me, I'd go look at it and haggle, but if you really
don't know what you're looking AT, walking away isn't a mistake.
There are a lot of things that could be wrong that would leave you
with a doorstop instead of a head.
