Mechanical Oil Pressure Gauge
jgerry2002
Snap-On Tools (order on line) from any mobil
tool truck - lifetime warranty of course
had a handy gauge with many different thresded adapters
inicluded - comes in a dandy red plastic Special Tool Box.
will last you a life time, and eliminate guess work
note: M10 engines have had 2-different low oil pressure switch
threaded holes during their production - this is why you'll need
the included adapters.
MT37A Engine Oil Pressure Gauge Set Overview
Use on diesel and gasoline engines. Includes standard and metric adapters for most popular domestic and import cars, trucks, tractors and stationary engines. Features bright, easy-to-read gauge with green protective boot. Includes plastic storage case.
MT37A Engine Oil Pressure Gauge Set Features:
Bright, easy-to-read gauge with green protective boot.
Works on domestic and import cars, trucks, tractors and stationary engines.
Helps find faulty oil sending units, oil pumps, worn main bearings, connecting rod bearings, as well as contaminated oil and dirty pickup screens.
Brass adapters attach to the flexible gauge hose, using special fittings for connection to hard-to-reach sending unit ports.
Optional accessories are available for testing mechanical fuel pumps and diesel injector pumps.
Pressure test range: 0 - 100 psi (700 kPA)
MT37A Engine Oil Pressure Gauge Set Standard Accessories:
0 - 100 psi (700 kPA) Gauge Assembly.
Hose Assembly.
Street Elbow.
2" LG Nipple.
Coupling.
Plastic Carrying Case.
Adapter, 1/8-27 to 1/4-18.
Adapter, 1/8-27 to 3/8-18.
Adapter, 1/8-27 to 18-28 BSPT.
Adapter, 1/8-27 to M10-1.0. (BMW )
Adapter, 1/8-27 to M12-1.5. (BMW)
Adapter, 1/8-27 to M14-1.5.
'64 R27 250cc #383851 18,000m
