SEALING YOUR BODY CAVITY 's
c.d.iesel
more useless information Part III.
1.0 General Information on Preservation Measures
The classic quality of BMW automobiles is based on
the long-term comprehensive research and testing,
the design, the applied materials and the manufacturing
procedures in modern production plants.
BMW recommends cleaning the engine, engine compartment,
vehicle underside, axles and engine/transmission at least
twice annually, and then waxing the car or repairing the
wax coating. This should be performed before or after
the period of salt usage on streets.
New cars parked outdoors should be waxed at BMW centers
before delivery to customers. This is to avoid deposits
damaging to the paint finish, such as air-born rust particles,
chemical dust, oil saturated soot, sulfur dioxide (acid) rain,
etc. settling on the horizontal surfaces. Bird and insect
droppings as well as tree resin could mar the paint finish,
formingspots, swelling and pitting in the paint coat.
Wax films on the engine, engine compartment and
A pillars (hinge areas) are intentional and prevent
corrosion. Such wax film should not be removed.
Unwaxed cars should be washed at least once each week.
Parked cars must never be protected with plastic or
other nonporous material covers. This will damage the paint
finish due to condensed water in conjunction with plastic
softener diffusion and scratching.
2.0 Body Cavity Sealing
It is only necessary to rewax or seal the affected area
after repairing the body.
Only BMW approved products may be used to comply
with the six year warranty against rust perforation.
These products protect cavities effectively and permanently
against corrosion. Their excellent coating and waterproofing
properties let them flow into all inaccessible corners and folds for unsurpassed overall protection.
Underbody and Body Cavity Sealing Compound
For sealing of body cavities, such as doors, A-pillars, front, side and cross members, etc.
(Former BMW Part No. 81 22 9 407 479)
3M Part No. 8891
Würth Part No. 892080
Also: Würth “Brushable Seam Sealer”, Part No. 8901021.
3.0 Body Corrosion Protection
To comply with the six year warranty against rust, specially
selected waxes and additives produce an elastic,
temperatureproof, corrosion inhibiting protectant. The
corrosion protection thickness should measure a
maximum of 30 microns, but can be varied as desired
by repeating the spraying procedures accordingly.
Procedure:
Clean underside of car to remove grease, oil and dirt.
Cover rotating parts and parts not undercoated, such
as driveshaft, brake discs, brake hoses, springs, exhaust
pipes, etc.
After completion of body repairs, the affected areas must
have corrosion protection reapplied. This applies, also,
if the BMW Annual Check shows that the corrosion protection
has to be repaired.
Underbody Sealing
Quick-drying, rubber-based, paintable. Compatible with
PVC-based undercoat, front apron and door sill coatings.
(Former BMW Part Nos. 81 22 9 407 001, 81 22 9 407 521/522)
3M Part No. 8883
Würth Part No. 892072
Loctite Part No. 81833 (or PX135EA)
CRC Part No. Siloo 28A
Also: Würth “Body Seal, beige”, Part No. 0892091 U.
Body Sealant, Light
Sealing compound for all joints and seams, can be painted
over. Good adhesion, free of shrinkage, resistant to heat
and cold temperatures, permanently elastic.
(Former BMW Part Nos. 81 22 9 400 013 and 81 22 9 407 313)
3M Part No. 8361
Würth Part No. 893430
Seam Sealer, White
Elasto-plastic sealing compound based on polyacrylate.
Applications: Protection of door and hood panel seams.
(Former BMW Part No. 81 22 9 407 675)
3M Part No. 8361
Würth Part No. 890100025
Also: Würth “Gray Seam Sealer”, Part No. 089228 U.
Transparent Wax
Prevents corrosion on painted and non-painted metal surfaces.
Serves mainly for treating edges and folded-over seams.
(Former BMW Part No. 81 22 9 400 711)
3M Part No. 8892
Würth Part No. 893082
Anti-Chip Compound
Sprayable coating compound for outside and inside. For
sealing, noise-insulation and as protection against flying
stones. Quick-drying can be painted over, permanently
elastic, heat and cold-resistant.
(Former BMW Part Nos. 81 22 9 407 001 and 81 22 9 407 416)
3M Part No. 8964
Würth Part No. 893075
Loctite Part No. 81833/PX135EA
4.0 Other Fluids
Adhesive Remover
(Former BMW Part No. 81 22 9 407 388)
3M Part No. 8984
and the money shot for 02 owners :
Rust Remover
(Former BMW Part No. 81 22 9 407 121)
Würth Part No. 89091801
Loctite Part No. 82075
WHEELS :
1.0 Tire Mounting Paste
Use only a lubricant specifically designed for this
purpose (former BMW Part No. 81 22 9 407 288).
Würth Tire Mounting Paste Part No. 892800
Silicone sprays are not acceptable, as they are
extremely slippery and don’t dry. If applied to the tire
bead, it is likely that the tire moves on the rim, causing
an imbalance.
See S.I. Bulletins B 36 02 88 (1627) or B 36 01 88 (1569).
2.0 Wheel Cleaners
Liquids for cleaning the alloy wheels must be strong
enough to lift brake dust, road dirt, etc. off the painted
wheel surface with minimum manual agitation, yet
not attack the wheel material. The following cleaner
has been thoroughly tested for optimum cleaning action
and long-term compatibility with the wheel’s surfaces:
Wheel Cleaner Spray BMW Part No. 82 14 1 467 045
3.0 Wheel Hub Covers
Covers may be affixed to the alloy rim by using
Loctite 638 (former BMW Part No. 07 58 9 056 030).
Covers may only be used once.
Loctite 638 - Würth Part No. 8936010
- Loctite Part No. 21447
The cooling-turbine wheel covers of the M5 (E34)
produced from March 1990 to October 1990 may be
secured to the wheel by applying Loctite 242 to the
attaching screw threads. First clean screw threads
with Loctite Cleaning Solvent 755.
See S.I. Bulletin B 36 03 90 (3182).
4.0 Anti-Corrosion Paste
Apply small amounts of Plastilube paste evenly around
the centering cone of the alloy wheel rim and onto
the contact areas of the brake hub.
Plastilube BMW Part No. 81 22 9 407 103.
'64 R27 250cc #383851 18,000m
