Spring Pads
qdessa
I thnk you've confused 3 things on 2002 suspensions:
1. The aluminum spacers used on top of the strut bearings (between the bearing and the body) on USA cars throughout their production (68-76). These can be removed to lower the front end about 5/8" with no problems, as the Euro cars didn't have 'em.
2. Rear upper spring mounts are rubber, and come in three thicknesses, denoted by dots drilled into the rubber: one dot is the thinnest, three dots the thickest. Most US cars had three dot mounts; you can replace with a one dot mount and lower the rear about 10mm (slightly less than a half inch)
3. All springs--front and rear--have thin rubber mounts to prevent the springs directly contacting their perches. Always leave these in place; otherwise you'll have excessive noise and wear.
Finally, all 73-76 US cars came with springs that are about an inch taller than the 68-72 cars. This was the factory's answer to Federally mandated bumper height requirements that began in 1973. On a 73-76 car, by removing the front spacer, going to a one dot rear upper mount and using 68-72 springs, you can lower your car around an inch or perhaps a little more (maybe 1.25")
hope that helps clarify things...
Rear upper spring mounts are rubber, and come in three thicknesses, denoted by dots drilled into the rubber: one dot is the thinnest, three dots the thickest. mike
when i re-built my rear suspension ~4 years ago, the one dots were NLA.
The two and three dots were still in stock.
Maybe this changed over the last years.
Colin K.
Malaga '72 tii
'76 2002 (Sold)
2002 Subaru WRX Wagon (at least it's a 2002)
