Tii Question on fuel air ratio
Tiger75
Be very sure that the timing is correct. If I remember there should be no advance at idle. This could make Any way, If you haven't already check that the ignition is in spec because this can cause or help to cause hunting as well. Linkages and Thottle body synced check for air leaks. Then if its still hunting make the idle adjustment a tad richer and see if that doesn't do it. On my car the no hunting setting was within the factory spec in terms of CO output.
Pete
