rear ended
I have a 71' 2002 that was rear ended a few years ago. The damage is not extensive but did cause the body to be pushed in about 2 inches and each of the rear quarter panels have bucked inward about 1/4 inch. Has only delt with this before? And if so do you think I am better off finding a donor car body or trying to pull the rear end back out?
The car is not in great shape as this is a project. Id be looking for a clean shell only, nothing else needed, with round eyes in the back.
Thanks for all your help, this is my first time posting.
- Tom
welcome to the site!
I don't know much about which would be a better idea. I have a rear lying around I've been planning on using to replace the rusted parts of my tii. I think it's probably be a good idea if you could find a doner for cheap/free
hope some body guys will chime in!
best of luck
PS
Justin says 'hydraulic ram!'
which is probably a good idea. I mean you can try using a ram or something to get it back into shape and if you screw it up horribly then you can always cut and weld as a last choice.
I agree- fine for a 'fix it and have fun' car,
but find something nicer if you're planning on a bare- metal resto.
And even if you chop a new tail panel on, pull the damage out first,
especially the 1/4 panels.
It's not a terribly hard fix, it just takes a LONG time to get all the panels
straight, and they never really like to stay exactly where they should...
