DCOE fule pressure
o2obsessed
Mcmil is right, about 3 to 3.5lbs. I do use an inexpensive fuel pressure regulator on both of my cars, '76 '02 with dual 40s and a '76 530 with triple 40s. I do not use a return line on either car.
2.5-3.5. I don't notice a difference.
I use a regulator and no return line, which may explain why the pressure ramps up when the engine is shutdown. There seems to be a bunch of different suggested pressures depending on when the information was published, and who wrote it. I remember seeing an "old" "wrong" (around 2 lbs) pressure and a new pressure that was slightly higher.
76 2002 40 DCOEx2 292 Shrick
1984 Mercedes-Benz 300D Turbo Diesel 240,000 miles
without seat recession problems...
but I run a pair of Holley Blue pumps (not the best choice, admittedly)
with bypass Mallory regulators.
TEP is a bit over the top on the whole fuel pump thing- as long as you have STABLE pressure, our cars don't need a huge amount of volume, even at WOT for long periods
The Carter pumps seem to have identical delivery characteristics to the Holleys- and I'd run a bypass regulator on 'em, just 'cause.
