1971 2002ti hard start
Fuel issue, more than likely. I'm still trying to figure out how to make the best system for my Weber 32/36. Today's gas evaporates much faster than the blends most carbureted engines were designed for.
Thank you for the reply. I have tried that technique when cold and has been sitting for days.  I do pump first and feather the throttle to light it up. Again warm start or siting for hours starts right up. Plugs: my memory is I am running a little hotter plug. Idle is great, car runs strong as ever.
Well, if there is insufficient fuel in the bowls at startup, the plugs won't do a thing. If you are experiencing "more" evaporation faster, have you changed fuel or perishing connections? I remember it took forever to fill the bowls with the mechanical pump...unless you pull the plugs to speed up the starter. I'm not sure who to believe on evaporation of E5 and E10 fuels, haven't really read into it.
1971 2002ti, 1985 E30 320i, 1960 Land Rover 109 Ser 2, 1963 Land Rover 88 Ser 2a, 1980 Land Rover Ser 3 Lightweight
I have this problem with my 2002 TI. The fuel leaks out of the carbs, you can test for this by filling some fuel in the carbs through the fuel line and see if it starts right up. I also put in a one-way valve in the fuel line to keep fuel from backing up completely. I use a really little funnel that fits into the fuel line.You might need lower carb gaskets, I think that's my problem. Your car symptoms sound exactly like mine. The health of your mechanical fuel pump may also be an issue. Good luck with it, Let us know what you find out. All the best, Peter
The First thing is to have an untroubled mind. The Second thing is to know your purpose. Illigitimati Non Carborundum
  • 1 month later...
Usually if the carbs are leaking you should get a strong smell of fuel.  The chance that on warm days or just when the engine is warm and you turn it off the fuel in the float bowls is “boiling” off and you have to crank the engine long enough to refill the bowls.  An electric fuel pump might be an easy solution.  This also helps on engines that sit a long time between uses.
Put the pump back by the fuel tank, they push fuel much better than they pull it.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
Thanks for the comment. Actually was only a cold start issue.  Solex carbs didi not leak. Hot start great. Jets clean. Timing good. Fuel flowing.  Then a few weeks later it resolved spontaneously 95%.  Since then made some changes to the ignition system. Running great.
