Different Pedal Assembly for 2002 EFI Conversion
...but does it drill lightening holes in your wallet?
heh
  • Haha 1
Hello All,
I really appreciate the input from everyone. But I didn't see what I was hoping for. Do we have any mechanical engineers on here that I could swap messages with?
Barry
1974 2002 - Fuel Injected, Bored, Balanced
Wide-Body Resto-Mod w/Lots of Goodies!
My sites - 2002BMW.com & HIDupgrades.com
BMW CCA - River City Bimmers
I have swapped email with him last year. He claims it does work well. But I want something in my engine bay that has a more factory look to it, like the pics I posted.
Barry
AVGs throttle arrangement "calms down" the off idle operation.  Mine is like and it is easy going off idle.  A pull straight off the firewall arm below can be twitchy.  Depends on how much street-ability you want.
Hahaha. Jim I too have now idea what I’m doing but , I do know that you know more than do   So I’m going to look closely at your suggestion because I want as much drive ability as possible
2 hours ago, 2002isGuy said:
What do you mean when you say - "calms down" the off idle operation?
Barry
Most probably the throttle valve is bigger than needed.  A slight movement off idle and the engine revs very fast.  The bell crank changes the ratio of % throttle to % gas pedal movement and the car pulls away from a stop mildly instead of a surge.  Surge seems to be what racers want, but is hard on the clutch life.  Experience driving each type and then choose.
Rlding a stud horse is a lot like a car with a wild throttle,  you gotta slap him around the ears with the reins to calm him down..
Edited by jimk
  • 4 weeks later...
@2002isGuy.
Here is a picture of the complete throttle rod/cable setup from the pedal rod in the pedal box to the cable to the throttles.
It shows the bell crank assembly made from 2 flatbar pieces bolted together and the bell crank.  The ratio of the legs on the bell crank were dimensioned to provide the pedal to cable pull ratio that suited me.
I removed the entire assemble when I went to a Drive By Wire throttle with the Haltech
