Door Jamb switch Bumper
VWScott
Go to solution Solved by bob02,
I am new to the BMW world and recently purchased a '76 '02. Anyway I am going through the electrics since many items are not functioning. One of which was the dome light. I fixed that...so I thought. Light works and when you manually depress the door jamb switch the light goes out. Great! So I put the car away and congratulated myself for a good start.I go out to the car today and battery is dead,ugh!!! I sat in driver's seat with the door closed and noted the dome light was still on. It was then I discovered a necessary piece to this equation.There was no rubber stop on the door and when closed the door jamb switch was not depressing.Passenger side does have the necessary part but not the driver side. What is this rubber part called? I Googled with no luck.Is this part available? and what are suitable alternatives for this. As it it stands the door has a hole looks to be 15mm where rubber stop is supposed to be located.Thks much.
'67 Derby Grey VW Beetle
'76 Inka BMW 2002
 It's little tedious to find the little bits, most everything is on RealOEM.
Don
WWW.REALOEM.COM
RealOEM.com BMW Parts website. This site can be used to look up BMW part numbers and approximate part prices. The Parts are grouped into diagrams and diagrams are grouped into categories and subcategories
WWW.REALOEM.COM
BMW parts 1502-2002tii 2002 Door, front
Edited by beammmer
Don
