Looking for a good place to tap for UNSWITCHED power
cvvick
Presuming this isn't a megawatt stereo/amp, the most convenient spot is the fat red wire on the back side of the ignition switch.  It comes VFR from the battery (no fuses, so be sure and have an in-line fuse for your stereo).
Check with a voltmeter (ign off) to make sure you have the correct wire, then use a piggyback terminal to hook things up.  Both my cars are wired that way and it works fine.
Just remember...if you have a radio with a memory, that's the wire that should be connected to the "always hot" lead on your stereo.  But use a switched (off with the ign off) source for the rest of the stereo, or you'll have to remember to turn it off every time you leave the car.  When our cars were built, radios didn't have memories, so you connected your radio to a switched power source.
The problem with tapping into a red wire is that it is not protected by a fuse. This would be OK if your stereo had its own fuse on the power cable.
Did I send you the attached diagram of fuses #1 and #2?
A good fuse-protected 12V (unswitched) source is the red/yellow to the lighter, or the red/white to the hazard button.
I'm not a fan of tapping into the ignition switch harness.
John
Another option would be to wire up an alternate fuse box under the hood connected directly to the battery, and independently wiring circuits from the box to suit your needs. Something like this:
WWW.BLUESEA.COM
Compact ATO® / ATC® fuse block consolidates branch circuits and eliminates the tangle of in-line fuses...
Thanks, yes, the stereo has an in-line fuse so this should work fine. I think I tap into the red/white wire on the hazard switch to avoid having to disassemble more and keep all the connection in the same place.
