2002tii master brake cylinder rebuild kits?
schuetz1619
Go to solution Solved by Stevenc22,
Has anyone recntly sourced reasonably priced rebuild kits for the tii master cylinder? The lowest I find is $280.
Is there possibly something for another car that contains the same seals?
Two years ago I got a tii master cylinder (FAG) for $200. Now they're north of $900. Whew.
While you are reconditioning the cylinder, check to be sure the leak-off hole is open.  It bleeds seepage from the inner seal so the fluid doesn't migrate into the booster.
I understand that brake master cylinder 34-31-1-120-832, from some E12 6-cylinder cars, is interchangeable with the unit speicified by BMW for the 2002tii:  34 31 1 120 47. Both are 23.81 mm. bore.
But are the guts interchangeable? Will a seal repair kit for one fit the other? Anyone know?
Thanks.
